05-16-2017 08:20 AM
it is very appreciated for your reply,according to your pdf file,can I say it that different chime signal has different amp and freq values,and we can judge what chime signal is playing by measuring it's amp and values?
what's more,can you kindly share the vi you use to measure chime signal' amp and freq.Thank you very much!
05-16-2017 09:12 AM - edited 05-16-2017 09:13 AM
Please understand the following:
I used the SIGNAL PROCESSING -> WFM MEASURE -> TONE MEASUREMENTS express vi for the purpose of measuring frequency and amplitude.
05-16-2017 10:53 AM
Also note, Amplitude of the audible signal may vary. It will be dependent on the proximity of the microphone to the speaker along with the volume of the speaker and the sound reflection/dampening in the vicinity.
05-17-2017 04:23 AM
Hi ,I think it will take me some time to do signal analyse work,because I am not very familiar with waveform computing.Hope I can handle it at last![]()
