Howdy!
I am getting an error that I need to work around. I have several messages that I need to send out periodically. I create an object for each of them and send them out. It works fine until I need to send the same ID with different command bytes (modes). Then I get an error. The error I am getting is Error -1074388969
Error -1074388969 occurred at NI-CAN configure CAN object (ncConfigCANObj.vi).
Possible reason(s):
NI-CAN: (Hex 0xBFF62017) This attribute's value must be provided prior to the Open. Solutions: Set the attribute using the Config function before the Open, and do not set the attribute at any later time; Do not configure multiple CAN Objects for the same ID.
Is there any way I can use objects to periodically send out the same message ID but different data (including mode byte)? I would really hate to have to re-write this to not use objects.
Thanks in advance for any advice you can give me.
Bob Young
