Using Frame Objects to send multiple messages
Howdy!
I am getting an error that I need to work around.  I have several messages that I need to send out periodically.  I create an object for each of them and send them out.  It works fine until I need to send the same ID with different command bytes (modes).  Then I get an error.  The error I am getting is Error -1074388969
Error -1074388969 occurred at NI-CAN configure CAN object (ncConfigCANObj.vi).
Possible reason(s):
NI-CAN:  (Hex 0xBFF62017) This attribute's value must be provided prior to the Open.  Solutions: Set the attribute using the Config function before the Open, and do not set the attribute at any later time; Do not configure multiple CAN Objects for the same ID.
Is there any way I can use objects to periodically send out the same message ID but different data (including mode byte)?  I would really hate to have to re-write this to not use objects.
Thanks in advance for any advice you can give me.
Bob Young
(4,957 Views)
Hi Bob,
You can only have one object for a certain ID. But you can change the data for that ID (object), when ever you want. Therefore you can call the Write object within a while loop and change the data input (8Byte) the way you want.
DirkW
(4,953 Views)
