Automotive and Embedded Networks
取消
顯示結果
搜尋替代
您的意思是:
Are new NI-CAN Series two cards backwards compatible with NI-CAN Version 2.1.2f2
We have a C++ application written with NI-CANTM Software for Windows 2000/NT/XP/Me/98/95 and LabVIEWTM Real-Time (RT) Version 2.1.2f2, our code was broken by a later release of the drivers but we could still use later hardware revisions if we used the old NI-CAN software.
We are having some issues with a new 1 port high speed series 2 PCI-CAN card 189063G-01 is this card backwards compatible with the software that we wish to use?
0 積分
1 條訊息(共 10 條)
8,582 檢視
Hello rico1,
The NI-CAN 2.1 driver supports the Series 2 PCI CAN.
What kind of issues are you getting when you use the latest drivers in C++?
Have a great day.
O. Proulx
www.ni.com/support
0 積分
2 條訊息(共 10 條)
8,563 檢視
I do not recall why the new software drivers are not backwards compatible, but that is not the problem.
I uninstalled Version 2.1.2f2 and installed the latest version and the same problem occurs.
The card will fail it's self test reporting that there is a memory conflict, if I go to the Windows XP device drivers tab resource page it reports that there is no conflict.
Unfortunately we have purchased 9 similar PC's - is there a way to fix this?
0 積分
3 條訊息(共 10 條)
8,546 檢視
Hello rico1,
The self-test error may be due to an NI-CAN application running on your computer or a NI-CAN dll that cannot be unloaded from memory. Have a great evening.
O. Proulx
www.ni.com/support
0 積分
4 條訊息(共 10 條)
8,528 檢視
There are no other applications that use the CAN card on the computer. I have not installed our software.
The card itself works when installed on a computer from another manufacturer - or even the same manufacturer but an older model.
0 積分
5 條訊息(共 10 條)
8,525 檢視
Hello rico1,
Please try to reset the card in MAX.  To do so, you need to press and hold <Ctrl> + <Shift> and right-click on the CAN card in the Measurement & Automation Explorer. Now, there's a 'Reset Card' option displayed. If you choose this option and confirm the following dialog, the entire CAN card will be reset.
Have a great week.
O. Proulx
www.ni.com/support
0 積分
6 條訊息(共 10 條)
8,483 檢視
I reset the card and tried the self test - it crashed the system.
I think we will need to use another PC manufacturer.
Thank you.
0 積分
7 條訊息(共 10 條)
8,473 檢視
Hello rico1,
Can you let me know the exact model of the computer you are using and BIOS version.  Thank you.
O. Proulx
www.ni.com/support
0 積分
8 條訊息(共 10 條)
8,471 檢視
Shuttle "Glamor" XPC G2 6800
AMD Athlon X2 Dual Core processor BE-2350
NVIDIA® GeForce 7025/nForce™630a chipset
Phoenix Bios v6.00 pg
0 積分
9 條訊息(共 10 條)
8,468 檢視
Hello rico1,
Do you have the name and part number of the motherboard that is in this system?  Thanks.
O. Proulx
www.ni.com/support
0 積分
10 條訊息(共 10 條)
8,414 檢視
