03-03-2008 03:49 PM
03-04-2008
04:09 PM
- last edited on
01-18-2024
01:45 PM
by
migration-bot
Hello rico1,
The NI-CAN 2.1 driver supports the Series 2 PCI CAN.
What kind of issues are you getting when you use the latest drivers in C++?
Have a great day.
03-05-2008 02:04 PM
I do not recall why the new software drivers are not backwards compatible, but that is not the problem.
I uninstalled Version 2.1.2f2 and installed the latest version and the same problem occurs.
The card will fail it's self test reporting that there is a memory conflict, if I go to the Windows XP device drivers tab resource page it reports that there is no conflict.
Unfortunately we have purchased 9 similar PC's - is there a way to fix this?
03-06-2008
04:58 PM
- last edited on
01-18-2024
01:45 PM
by
migration-bot
Hello rico1,
The self-test error may be due to an NI-CAN application running on your computer or a NI-CAN dll that cannot be unloaded from memory. Have a great evening.
03-06-2008 07:18 PM
There are no other applications that use the CAN card on the computer. I have not installed our software.
The card itself works when installed on a computer from another manufacturer - or even the same manufacturer but an older model.
03-10-2008 08:00 AM
03-10-2008 01:27 PM
I reset the card and tried the self test - it crashed the system.
I think we will need to use another PC manufacturer.
Thank you.
03-10-2008 01:37 PM
03-10-2008 02:17 PM
03-13-2008 05:48 PM
