Automotive and Embedded Networks
CANopen nodes
Hi
What data Types CANopen protocol support. How to convert Array of U8 into I8, I16, I24, I32, I64.
Regards
J
(7,335 Views)
 Hello J,
The CANOpen library only supports the U8-array data type.  I have attached a VI which demonstrates how to extract data from that array using the "Index Array" VI from the Array functions palette.   I have also demonstrated how to convert this data type into other data types using the conversion vis located in the Numeric -> Conversion functions palette.
Let me know if this answers your question.  Have a great day.
O. Proulx
www.ni.com/support
(7,325 Views)
Hi Proulx
Thanks for your kind response.
I am not able to open the .vi since i am using labview 8.2.
I also wants to converts Array of U8 data type into Integer 24, Unsigned 24, Octet String & Unicode String Because in the end After reading data from various Index & sub index , i have to display all the data in the Multicolumn Listbox. So i have to convert all the data types (Array of U8 data ) supported by CANopen into string.
Regards
J
(7,322 Views)
Hello J,
I've re-attached the VI saved in version 8.2.   I added a conversion that uses the "Number to decimal string.vi" which should help.  This vi can be found in the "String -> conversion" palette.  As for the other data types you need, you can look into the "numeric -> conversion" palette.  You may need to use a boolean array to create your own 24 bit number, since LabVIEW does not natively support this datatype.
O. Proulx
www.ni.com/support
(7,317 Views)
The CANopen Library itself brings two polymorphic VIs to convert in both directions. (CANopen Convert to Data, CANopen Fetch from Data).
DirkW
(7,308 Views)
Hi
Thanks for the reply. I am not using the CANopen Library functions. I am only using Frame API available with labview 8.2.1.
Regards
J
(7,306 Views)
