09-28-2020 04:28 PM
Since this is taking so long (why???) I took a look and made another attempt at creating my own fix for the rescripting issue in interfaces which I've attached. I've tested it for standard coupled messages and I don't see any appreciable slowdown at the moment, but I can't guarantee that it covers every use case and is as robust as the original since I can't see that source code.
Anyway... hope this help some people out.
09-28-2020 07:14 PM
Unofficial patch here: Patch for LabVIEW 2020 AF Project Provider, Fixes Incompatibility with Interfaces.
09-28-2020 08:16 PM
"Unofficial" only in the sense that it isn't NI published. But Allen and I have both vetted each other's work on this... he was the one with the bandwidth today to actually publish it! But these are the fixes that will eventually be in a patch for LabVIEW 2020.
09-28-2020 08:42 PM
Thanks, Stephen! I didn't want to speak out of turn...
09-29-2020 12:05 AM
09-29-2020 09:50 AM
Sorry for the delay. This has not been a normal season by any stretch, and we've been slower responding to many issues than in the past.
10-27-2020 05:03 AM - edited 10-27-2020 05:04 AM
I have just been bitten by this, so thank you for the fix! (: It works as expected!
01-15-2021 10:50 AM - edited 01-15-2021 10:50 AM
I think this issue needs to be re-opened as I've found conditions where the patch doesn't work as intended.
I still saw this issue popping up from time to time and I didn't take the time to really figure out when it happened until just recently, but it seems that while the issue is resolved for normal interfaces, if the interface happens to be contained within a PPL, then the original bug still exists. I'm attaching code that demonstrates what I'm talking about.
Steps to reproduce:
A patch for this would be much appreciated as I'm in the midst of a large project where we intended to switch to interfaces that are a part of PPLs.
I'm going to open a support request for this as well so try and get more NI eyes on it as well. Speaking of which, did the original patch ever make it to a release? The release notes for any and all versions up until this point don't seem to indicate that is has. Also, is there a CAR associated with the original bug that I can reference in my support request?
01-15-2021 10:56 AM
