MyRIO simple code compilation FPGA
I am new to FPGA and I want to compile some simple code. I know that myRIO comes with default FPGA configuration so I want to create new one and compile it. Lets say that I want blinking LED. So I create new VI on FPGA and here is simple code:
then I add it to build and start compilation
As compilation goes it says that it will use 30% of FPGA resources:
Why is that? Whole compilation on cloud server takes more than 20 minutes. I have seen some example videos on CRio FPGA and that simple code should use no more than 2% of resources and shuld compile in 2 to 3 minutes.
What I am doing wrong?
Thanks in advice
(6,791 Views)
Hey Pawhan11,
There are two main reasons for the FPGA resource consumption.  First is that the FPGA on the myRIO (Zynq Z-7010) is relativly small compared to some other NI targets you may have used.  The second reason that even a simple FPGA application takes ~20% of the FPGA fabric is because some of the FPGA fabric is already being used for other purposes.  For example some NI Real-Time targets implement UARTs, RS232 or even ethernet in the FPGA to ensure consistency between devices.
Since myRIO is based on the Xilinx Zynq chip it uses a different toolchain than previous FPGA devices which may cause the difference in compile/synth times.
-Sam K
LabVIEW Hacker
Join / Follow the LabVIEW Hacker Group on google+
(6,789 Views)
