I need NI myDAQ schematic
Hi all,
I accidently damaged my 15V rails and I suspect I damaged the internal opamp.
My multimeter shows a pulsating output at the 15v rails.
Can I have the scematic diagram so that I can repair it?
Thanks.
(5,297 Views)
If you possess the skills to modify the board, what use is the schematic?  You can take a look and see the opamp.
(5,290 Views)
I use myDAQ quite heavily and reverse engineering can be time consuming.
I need it just in case I broke another part of the circuit.
Future proofing myself? Smiley LOL
(5,288 Views)
If you are really interested in this, I would recommend on calling into the NI support line.
I would pretty surprised if you got a full schematic but that's probably the right way to go about this.
(5,257 Views)
I will give it a go.
Thanks for the tip.  🙂
(5,238 Views)
