NI myrio in Eclipse IDE: cannot load NiFPGA library error
Hello! I have just  started working with the NI myRIO 1900 model using the Eclipse IDE . I tried to build and run some of the NI myRIO C examples by following the procedure in the 'C_support_for_myRIO_User_Guide' document given by NI. It builds without any error but throws this error whenever I try to run any of the programs :
" ERROR: -63194
Could not load NiFpga library!"
It would be really helpful if anyone could suggest any solution for this issue. Thank you
(4,476 Views)
Accepted by topic author anj123
(4,427 Views)
Hi RAO!
Thank you so much for the links, updating the software on the target board helped! The codes are running fine now!
Anjana
(4,418 Views)
