キャンセル
次の結果を表示
次の代わりに検索
もしかして:
Generate Sine wave on analog port of myRIO
I want to generate a sine wave of a known frequency and amplitude on analogue out (ConnectorA/AO0) of myRIO.
Any ideas how to do that? I have tried looking at example codes in the forum but nothing has worked for me so far.
Best Regards,
Mubeen Haadi.
0 件の賞賛
メッセージ1/28
8,242件の閲覧回数
There are a couple of approaches we can take for this task. There is an example VI included in the NI Example Finder named "Customized FPGA Signal Generator" that will allow you to do this without having to add anything to the code. Additionally, you can use the "Ex_Inst_Simulate Signal" Express VI to configure and generate analog output signals.
メッセージ2/28
8,210件の閲覧回数
Hi, thank you for diracting me to that example. that is really good example code and now I am understanding how the signal generation is working. I was wondering though what is the highest frequency that can be generated?
can you give me another "hint" on how I can generate and read a sine wave simultaneously ?
0 件の賞賛
メッセージ3/28
8,198件の閲覧回数
The highest frequency will be dependent on a few things: if you're running the code on your PC it will be based on your computer's timing, if it is running on the FPGA, what else is running on the FPGA, or if you are creating this signal to run as analog output it will be be based off the analog sample timing. So it is going to be hard to determine the highest rate that we will be able to run at any given time but more about the myRIO timing can be found in the following spec sheet.
NI myRIO-1900
http://www.ni.com/pdf/manuals/376047c.pdf
Also, to read simultaneously you could read the signal you are generating via a graph indicator on the front panel.
0 件の賞賛
メッセージ4/28
8,190件の閲覧回数
Hi, the following image shows the code for the FPGA side and the configuration of the sine wave generator. The quality of the sine wave drops considerably when I increase the frequency beyond 500 Hz?
すべてをダウンロード
0 件の賞賛
メッセージ5/28
8,188件の閲覧回数
If you change the amplitude resolution does the quality of the sine wave improve?
0 件の賞賛
メッセージ6/28
8,162件の閲覧回数
yes, the lower the amplitude, the better the quality.
0 件の賞賛
メッセージ7/28
8,157件の閲覧回数
Have you tried interfacing with the "Ex_Inst_Simulate Signal" Express VI on the Real-Time target instead of the FPGA?
0 件の賞賛
メッセージ8/28
8,084件の閲覧回数
how do I do that? can you share a screen shot?
Best Regards,
Mubeen Haadi.
0 件の賞賛
メッセージ9/28
8,079件の閲覧回数
You would need to structure your project similar to the attached image with the Waveform Generation VI located on the device but not located on the FPGA.
0 件の賞賛
メッセージ10/28
8,058件の閲覧回数
