Generate Sine wave on analog port of myRIO
Where should I place SimulateSignal Express VI?
I am New to LabVIEW FPGA Plz Guide
Message 11 of 28
(3,523 Views)
Hi manya,
If you have LabVIEW 2017, use the NI Example Finder to load up the example Express VI - Amplitude and Level Measurements.vi. This demonstrates how to simply use the Simulate Signal Express VI inside a while loop. You can also read the Using the Simulate Signal Express VI to Generate Waveforms article and the Simulate Signal Express VI Help page.
If you're using the FPGA Module, use the NI Example Finder to load up the project Customized FPGA Signal Generator.lvproj. You can also read the Sine Wave Generator Express VI Help page to learn more.
Mike B.
Technical Support Engineer
Message 12 of 28
(3,508 Views)
As you suggested, I have used Customized FPGA Signal Generator.lvproj.  to generate signal. Thanks
I have Attched code pic here, I want to generate sine waveform and diplay on the oscilloscope but I  able to get  DC levels  on Oscilloscope Scope.
How to get Contineouse sine signal on Oscilloscope for given Code ?
Message 13 of 28
(3,503 Views)
I see from your screenshot that you're using a MathScript Node. What happens when you run a more simplistic example with, say, a sine wave? You can read the Analog Output Express VI Help page to better understand how the VI is used. Reviewing 1 Sample versus N Samples Modes (myRIO Toolkit) may also be helpful to make sure you're sampling the way you're expecting. Additionally, it may prove useful to review the code posted by users earlier in this thread.
Mike B.
Message 14 of 28
(3,492 Views)
Dear, I am new to LabVIEW FPGA.  plz Send me relevant Video tutorials links for high throughput programming.
Message 15 of 28
(3,480 Views)
You can watch tutorial videos at Getting Started With LabVIEW FPGA. The Getting Started with the FPGA Module Help pages are also a good place to begin learning.
Mike B.
Message 16 of 28
(3,477 Views)
hello,
We have  generated  sine wave Successfully Thank You very much..
but We want to further modify our code so initially we want to add "for loop" in mathscript node,
when we have added for loop for further  manipulations, the sine waveform is not coming properly .
Message 17 of 28
(3,431 Views)
hello,
Message 18 of 28
(3,427 Views)
          I have downloaded a LabVIEW code to Ni MY RIO 1900
which has maths script node with for loop inside node but I could not get output waveform properly.
This is because of use of for loop inside maths script node. MY RIO BECOMES TOO SLOW.
Please guide
Message 19 of 28
(3,425 Views)
Hello manya,
I believe it is easier for the community to help out if you also provide the image of the changes you made to your code.
Additionally, what do you mean by the myRIO becoming too slow? Do you see a 100% CPU usage? Have you benchmarked the node/VI that is giving you problems? How fast do you need it to go vs. how fast it is actually running?
Message 20 of 28
(3,419 Views)
