Signal Generators
Hello I Want Labview Control An Indicator By Voice Recognition
Hi deepAg,
Which VI are you trying to run?
It may be helpful to repost your question as a new thread since it's been a while since this forum has been touched.
Have a good day!
Anna L
Message 31 of 34
(4,813 Views)
Hi deepAg,
I would have to second that recommendation, to post this as a new thread. You should also post it to a more appropriate board as well, as it would get much more visibility from people who are more knowledgable in the subject matter since this board is typically monitored by people using NI Signal Generators (NI 54xx devices). The LabVIEW board can be found here: http://forums.ni.com/t5/LabVIEW/bd-p/170 .
Jason L
Product Support Engineer
Message 32 of 34
(4,801 Views)
Spoiler
Can anyone help in extracting text from speech Using Labview? We could not run this using the above code.  Can any one tell how to execute that above program?
Message 33 of 34
(1,770 Views)
  • Is there a reason you are using spoiler tags in your reply??
  • If you refer to "above code", provide a link. There is a lot of code in this thread.
  • If something does not work, you also need to explain what happens (don't know how to use it, don't have LabVIEW, code is broken, incorrect result, computer bursts into flames, etc.)
Message 34 of 34
(1,766 Views)
