07-30-2013 11:09 AM
How do I create a simulated IO vi. I have tried to follow the tutorial but it didn't work. Do I need a pre filled array with data for the running case or can I generate it with an express vi? My IO vi doesn't seem to enter Running case ever. What is the process of executing this VI? is it run once or every time the main vi tries to sample some data?
07-31-2013 10:14 AM
Hi Bartekluk
Which tutorial have you been following? Please post the link and I'll take a look.
Kind Regards
08-01-2013 03:37 AM
I found an example in Labview and it was more informative than test benches tutorial. I managed to solve my problem.
07-23-2015 11:15 AM
Hello I've a similar problem. I want ot simulate a sinusoidal input for my cRIO and I followed the example about the Dynamic IO generation but when I launch my VI with the light bulb on for every iteration I get the same value for my Module.
Here are my VIs
