NI TestStand
deployed labview project has conflicts
I'm having an issue with a teststand deployment (Teststand 2013, LabVIEW 2013)
I have a deployment which deploys my LabVIEW project containing all drivers (classes and lvlibs) for use in my sequences.
In the deployment (LabVIEW options), I uncheck "exclude vi.lib", "exclude user.lib" and "exclude instr.lib" because the deployment should also work on an PC that only has runtimes and an operator interface.
The build finishes without errors but I cannot open the deployed project...
--> not on a development PC because it finds conflicts (XNodeSupport and some vi's in vi.lib picture.llb)
--> not on a runtime PC (file not found)
Did anyone else notice the same behaviour ?
It works with LabVIEW and TestStand 2010.
Thanks in advance for your help, tips and tricks 🙂
(Cross post, also on Lavag.org: here
(5,155 Views)
Is this the first time you are creating depolyment with LabVIEW and TestStand 2013? Did the same deployment work in earlier version?
(5,115 Views)
It worked well in 2010.
We upgraded the project to 2013 and then it stopped working.
(5,104 Views)
Accepted by Wim.Tormans
Together wit NI we have found the problem.
The GDS (Goop development suite) causes the conflicts.
The problem is identified, solution is pending.
Cheers,
Wim
(5,037 Views)
