Test Stand: How does parameter's value is passed as command line argument?
Hi All,
This is my 1st Q on this board.
I'm using Test Stand Sequence to call a subsequence where I call an executable file and passing few arguments to it.
SuperSequence.seq => SubSequence.seq
In SuperSequence.seq I have 3 parameters and their values are specified
Parameters
Name      Type    Value
Name      string    "Nirvana"
Address  string    "London"
Tel           Number "123456"
In SubSeq.seq I call and EXE with following parameters
Executable Path Name: myApp.exe
Argument Expressxion:  "Parameters.Name  Parameters.Address  Parameters.Tel"
In the application I receive parameter names instead of their values?
E.g. I recevie Parameters.Name  Parameters.Address  Parameters.Tel in myApp.exe as arguments.
How do I make the values to be passed to myApp.exe instaed of parameter names?
Cheers
Nirvana
(2,874 Views)
You have to make a string containing the arguments that you require
Try the following expression
Parameters.Name  + " " + Parameters.Address + " " +Str( Parameters.Tel)
Regards
Ray Farmer
Regards
Ray Farmer
(2,868 Views)
Thanks Ray for quick response,
I'll try to make it work and will update.
Cheers
Nirvana
(2,848 Views)
