Some of our tests (VIs) have significant interaction with test equipment, and perform a large number of measurements, and comparisons to ranges to determine pass/fail. We do all of this inside the VI's by having them read a config file when they run, they perform the test, use the range info (from the config file) to determine pass/fail, then they report back to TestStand whether the test passed or failed. The test step is of type Pass/Fail. For several reasons, we did not use the Multi-Numeric step type. However, we want to add to the Report Text the ranges and measured vales. We pass all this data back to TestStand, but currently don't do anything with it. How can we insert that information into the report? Do we use AddExtraResult somehow?
