06-23-2017 10:09 AM - edited 06-23-2017 10:14 AM
Hi, I'm trying to install the Moxa Nport 5323 drivers on Linux RT (x64 in my case) by starting from the driver available on this page and following the installation instructions located into the README.txt file provided with the driver itself (attached as well). To summarize also below:
-) on the target, I extract the .tgz file under / folder
-) install packagegroup-core-buildessential & ldd packages from our feeds since the readme requires the following softwares:
- kernel 2.4.x or 2.6.x or above and the kernel source package
- gcc-2.7.2.1 or above
- ld.so-1.7.14 or above
- libc.so-5 or above
- binutils-2.7.0 or above
- make-3.74 or above
- gunzip-1.2.4 or above
- gawk-3.1.1.9 or above
- openssl-0.9.8a or above (For Secure Real COM Mode only)
-) run source /usr/local/natinst/tools/versioning_utils.sh
-) run setup_versioning_env
-) run /tmp/moxa/mxisnt command. Here's the first error I get
make -C /lib/modules/4.1.15-rt17-4.0.0f0/build SUBDIRS=/tmp/moxa modules
make[1]: *** /lib/modules/4.1.15-rt17-4.0.0f0/build: No such file or directory. Stop.
Makefile:65: recipe for target 'module' failed
make: *** [module] Error 2
-) I tried to create the /lib/modules/4.1.15-rt17-4.0.0f0/build folder and try again
admin@NI-CVS-1458RT-01AF6922:~# /tmp/moxa/mxinst
Copyright (C) 2002-2012 Moxa Inc.
All Rights Reserved.
MOXA NPort Server Real TTY Driver V1.18 Installation.
System Imformation: Kernel 4.1.15-rt17-4.0.0f0; Machine x86_64.
Tar files, please wait ... OK!
Building driver...
If you want to use secure communication with target,
you might choose [y] to enable the SSL function.
Note: This function support RealCOM with secure mode only.
Do you want to enable secure function? [y/N].
make[1]: Entering directory '/lib/modules/4.1.15-rt17-4.0.0f0/build'
make[1]: *** No rule to make target 'modules'. Stop.
make[1]: Leaving directory '/lib/modules/4.1.15-rt17-4.0.0f0/build'
Check Driver...
FAILED !!!
How can I solve this error?
Tx
06-23-2017 10:31 AM - edited 06-23-2017 04:22 PM
Hi Fabio,
The error messages that you're seeing are due to the Moxa download attempting to build kernel modules by looking for the needed headers/configuration information in the standard location for these things. Unfortunately, the NI Linux RT distribution does not keep the needed resources in the default location, so you will likely need to modify the scripts that the Moxa package comes with to use the tools described in the tutorial here or the video here
06-27-2017 12:03 PM
Update: i tried to look into the makefile of the driver and found out that the line that starts the make process is:
$(MAKE) -C $(KDIR) SUBDIRS=$(PWD) modules
I set KDIR to /var/volatile/tmp/headers/kerne and changed SUBDIRS with M ending up with
$(MAKE) -C $(KDIR) M=$(PWD) modules
the build fails and I see a new warning saying "LINUX_VERSION_CODE" is not defined. How can I set it? Compiling the same code on a ubuntu 14.04 works fine.
06-28-2017 04:33 AM
Hey all, please discard my last post. I did further analysis and I manage to make the moxa script look to the right location of the kernel symbols. This led me to another issues, that is described by the make output here below:
make[1]: Entering directory `/home/tux/Desktop/nilinuxrt/linux'
CC [M] /home/tux/Downloads/moxa/kernel3.x/npreal2.o
In file included from include/linux/spinlock_types.h:19:0,
from include/linux/spinlock.h:81,
from include/linux/seqlock.h:35,
from include/linux/time.h:5,
from include/linux/stat.h:18,
from include/linux/module.h:10,
from /home/tux/Downloads/moxa/kernel3.x/npreal2.c:39:
/home/tux/Downloads/moxa/kernel3.x/npreal2.c: In function ‘npreal_init_tty’:
include/linux/spinlock_types_rt.h:42:2: error: expected expression before ‘{’ token
{ .lock = __RT_SPIN_INITIALIZER(name.lock), \
/home/tux/Downloads/moxa/kernel3.x/npreal2.c:597:22: note: in expansion of macro ‘__SPIN_LOCK_UNLOCKED’
tty_node->tx_lock = __SPIN_LOCK_UNLOCKED(tty_node->tx_lock);
make[2]: *** [/home/tux/Downloads/moxa/kernel3.x/npreal2.o] Error 1
make[1]: *** [_module_/home/tux/Downloads/moxa/kernel3.x] Error 2
make[1]: Leaving directory `/home/tux/Desktop/nilinuxrt/linux'
Check Driver...
FAILED !!!
it seems that the npreal2.c is designed to use "standard" muxes while our kernel redirects to use rtmutexes instead. For this reason, the following line in npreal2.c file:
works fine if the __SPIN_LOCK_UNLOCKED is the one defined under spinlock_types.h
#define __SPIN_LOCK_INITIALIZER(lockname) \
{ { .rlock = __RAW_SPIN_LOCK_INITIALIZER(lockname) } }
#define __SPIN_LOCK_UNLOCKED(lockname) \
(spinlock_t ) __SPIN_LOCK_INITIALIZER(lockname)
#define DEFINE_SPINLOCK(x) spinlock_t x = __SPIN_LOCK_UNLOCKED(x)
but gives error using the one defined under spinlock_types_rt.h
#define __SPIN_LOCK_UNLOCKED(name) \
SPIN_DEP_MAP_INIT(name) }
#define DEFINE_SPINLOCK(name) \
spinlock_t name = __SPIN_LOCK_UNLOCKED(name)
Can you give me some guidance to adapt npreal2.c code to adapt to rtmutexes? Is it enough to use rtmutexes or do I expect to encounter other errors, based on your experience?
Fabio
06-28-2017 11:47 AM
Basically, it comes down to whether or not the locking in the module depends on traditional spinlock behavior of disabling preemption (usually not required for most drivers that use them) or if it simply needs to maintain module state/behavior (read: guarantee that other threads of execution won't interfere with the code protected by the lock, a traditional mutual-exclusion-type requirement for execution).
07-01-2017 12:43 AM
Quick update: to make the driver install on NI Linux RT targets (so far it's been tested on 16.0/4.1 and x86_64 cpus) you need to change the way the spinlock init code in the npreal2.c file. One approach could be calling the macro right when the struct that contains it is defined:
//static struct npreal_struct npvar_table[NPREAL_PORTS];
static struct npreal_struct npvar_table[NPREAL_PORTS] = {
[0] = {
.tx_lock = __SPIN_LOCK_UNLOCKED(npvar_table[0].tx_lock)}
Then there are these other small changes to make:
-) In the makefile, modify the way the KDIR variable is initialized, by letting user to add it as an argument when calling ./mxisnt
-) In mxaddsrv.c and mxloadsrv.c, there's an if statement at the beginning of the code that sets the os variable to identify the distribution type (redhat, debian, etc,) that you're running the script. To make it work on nilinuxrt, you need to move from the linux case to the debian case, to make use of the right init.d directory where to store init scripts.
Once you make these changes, you can successfully compile the driver (either on the rt target or through a cross compilation).
Unfortunately, this is just half of the path to make things work. To be able to map the serial ports (ttyr<xx>) under the nilrt os, you need to recompile the kernel with the LEGACY_PTYS options disabled. You can find it using menuconfig under device drivers -> character devices . Follow the steps detailed here to compile and deploy the new kernel on your linux rt target.
Thanks a lot to BradM for the precious suggestions,
Regards
07-23-2018 07:40 AM
Why not just using the mainline moxa driver ?
https://www.kernel.org/doc/Documentation/serial/moxa-smartio
03-25-2020 05:08 AM
Hello Chuck_81,
I am having a similar problem you had: trying to install driver for MOXA nPort 5410 on cRIO-9045.
I already tried some things you explaind, but didn't get it working yet.
You set KDIR to /home/tux/Desktop/nilinuxrt/linux. What is in this path? Is there the Kernel Header? And if yes, where can I get the right files from?
Would be great, if you could give me some ideas to get the driver installed.
Thanks in advance!
BR
Josef
04-03-2020 05:30 AM
Hi, find here file that should be correct. What you need to do:
https://1drv.ms/u/s!AurpJeCRcBYcgWhoQUySfgM2Q1r2?e=nrjzY0
-) Download the file
-) on a Linux Machine, or on the cRIo target, unzip the file
-) Follow the steps on the readme.txt to build it.
If you compile on the target, please install these prerequisities:
basically referring to my first post.
Let us know how it goes.
