error 200428 in linux example code
Hi All;
I'm trying to use the mx daq-base on a redhat 9.0 system. I have a 6031E installed(pci). I've installed the hardware, then the software and compiled the example code. When I try to run the writeDigPort example I get;
Device indentifier is invalid.
DAQmxBase Error: -200428
lsdaq reports:
NI 603E: "Dev2" (PXIO::16::0)
Nay ideas?
Pat
(2,838 Views)
After further looking into the problem I'm getting an error -200220
here is the suspect code
char chan[] = "dev1/port0:1";
error1= DAQmxBaseCreateDOChan(taskHandle,chan,"",DAQmx_Val_ChanForAllLines);
DAQmxBaseGetExtendedErrorInfo (errBuff, 2048);
printf("\nDAQmxBaseCreateDOChan returned %d %s",error1,errBuff);
This gives the following output
DAQmxBaseCreateTask returned 0
DAQmxBaseCreateDOChan returned -200220 Device identifier is invalid.
Data to write: 0x55
DAQmxBaseGetExtendedErrorInfo returned -200428 Value passed to the Task/Channels In control is invalid.
Anyone have any idea?
Pat
(2,819 Views)
Greetings,
Changing
to
char chan[] = "Dev2/port0:1" should solve your problem.
Reply back if you are still having trouble!
Good luck,
Anuj D.
(2,812 Views)
Great that was it. I cant beleive I didn't see it!
Pat
(2,806 Views)
