can I connect a bently nevada prximity sensor 3300XL to 4 channel NI9234 DAQ
We have bought a Bently Nevada 3300XL proximity sensor which comes with a Miniature coaxial ClickLoc connector with connector protector, standard cable . We have a 4 channel NI9234 DAQ.
Please any suggestions on the type of adaptor to use?
Thank you.
(5,535 Views)
A quick search of the datasheet tells me that you need a -17 to -26V powersupply with at leat 12mA. (Not possible with the 9234)
The output voltage range of the sensor is higher than the input voltage range : -19V (sensor) to -5V (9234) so a voltage devider  is needed if you need the range (two resistors 3:1  say 3k and 1k )
I would build a power supply box with a -24V and 10V (12V) supply and add a OP(with 36V supply range)  and 4 resistors to build a level shifter  -1 to -20V  -> -5 to +5V 🙂
(and since you asked that question, try to find a EE student or someone who knows where the hot end of a solder iron is, to build it for you)
 EDIT: Some capacitors to buffer /filter the circuit are needed too  😉
Greetings from Germany
Henrik
LV since v3.1
(5,528 Views)
Thank you for the suggestion.
However, could you also suggest which NI DAQ would be suitable for direct connection with the sensor/
I feelit best to avoid the added circuitry as it might introduce noise?
Thank you,
(5,487 Views)
Accepted by fesmi
I'm not a NI app engineer , however as far as I know there is no NI-DAQ with a -24 V powersupply and a -20V input reange.
Maybe the other way: What do need to measure ?  Your sensor seems to have a quite high nonlinearity ... maybe look for another sensor?
Henrik
LV since v3.1
(5,478 Views)
okay, Thanks a lot..
(5,432 Views)
