Data Acquisition
Hello friends,
I have a task of acquiring continuous samples from two C series-NI9215 cards mounted on cDAQ-9171. The technique available on
http://forums.ni.com/t5/NI-DAQmx-Examples/Synchronize-Continuous-Acquisition-of-Multiple-Analog-Inpu...
does not include for the case for C series. Can somebody please help me regarding this. It would have been better if the logic behind using these blocks is also exlained as I'm a beginner in data acquisition.
Thank you all in advance,
Gajanana Abhyankar B
(2,939 Views)
Personally, I would just buy a cDAQ-9174, which is a 4 slot cDAQ chassis.  Then you just create one DAQmx task with all of the channels and it is all taken care of for you.
GCentral
(2,934 Views)
I have a cDAQ-9184 chassis which is ethernet enabled. Is that OK if I mount the C series NI9215 on that chassis.
(2,931 Views)
Accepted by Gajanana
That would work as well.
GCentral
(2,914 Views)
Yeah, I mounted both NI9215 cards on cDAQ-9184, also added all 8 channels from both cards as a single task. But unable to synchronize. Is there a solution for this..?
(2,876 Views)
