Motion Control and Motor Drives
Is SERCOS supported by NI-Industrial Communications for EtherCAT?
The EtherCAT standard supports several different Mailbox Protocols:
(source: http://www.ethercat.org/en/technology.html )
However, the following page from the LabVIEW IDE (LV 2013 SP1 + NI-IndCom for EtherCAT 2.7) suggests that only a subset of these protocols are supported by NI (CoE, EoE, FoE):
I was hoping to use a CompactRIO to control a Beckhoff AX5203 servo drive, which uses SERCOS over EtherCAT (SoE).
Could someone please confirm whether or not NI-Industrial Communications for EtherCAT supports SoE? If not, are there any plans to add support in the near future?
Thanks.
Certified LabVIEW Developer
(7,259 Views)
Accepted by topic author JKSH
Hey,
LabVIEW does not by default support SoE; however, I know that there are some libraries made by 3rd parties for use with their harware that support it. You may want to take a look here.
EtherCAT Acquisition Lib for LabVIEW™
http://www.ackermann-automation.de/ecatlv_en.htm
Britton C.
Senior Software Engineer
(7,238 Views)
