03-27-2013 08:56 PM
Are you saying that you are getting an active error? That message in that spot is really a short history. You should be concerned about the active error. 100 degrees is huge in the servo world. It doesn't sound like you have it tuned correclty. Also, I want to make sure you aren't using a load mounted encoder(second encoder). That can throw a following error also. Yes, the setting you have should ignore a following error. You usually don't want to do that, though.
03-28-2013 12:41 PM
Ok,
I fixed the problem by switching the assignment mode back to "free' rather than "fixed." I was using a previous configuration prior to changing that setting and forgot to check it.
Now everything runs fine.
Now's the time for tuning.
Thanks for all the help everybody.
03-30-2013 01:45 AM
Check out this link...
04-08-2013 06:24 AM
Hi Dave, Can you leave a brief note on all what you did to establish communication and finally get the motor running? Visitors may be benefitted!
04-08-2013 04:47 PM
I said it up above, I changed the assignment to free from fixed. That allowed me to activate the axis which told me that serial commands were working properly.
I knew the axis was activated because it hums.
Now I am working on torque control with the controller setup as I10T10 and with the input simulation in the optimization window, it is indeed working. We just need to figure out what the reference voltage range from -10 to 10V corresponds to what torque we get back from it.
07-12-2013 10:35 AM
I feel your pain! I bought a Compax 3 a few years ago, and it took me three months to get the thing to turn, and that after I challenged my supplier to show me where in the manual it actuually tells you how to make it go.
The trick is that the "go" bit of the status word (IIRC, it's 16 bits long). Has to be set to 0, then 1, then 0. So 3 operations instead of one, which didn't impress me. Anyhow, I programmed it in VB6. Here's a couple of subroutines, which I hope will help:
Public Sub motor_init() 'Initialise communications with motor
Dim temp
servo_comm = MSComm.CommPort 'Com port selected on props panel = COM1
Label4.Caption = "Com Port " & Str(servo_comm) & " connected"
If Not Connect Then 'If not already connected
If MSComm.PortOpen = False Then
MSComm.PortOpen = True 'Open the Comm Port
Delay (100) 'Allow for connection time
End If
MSComm.Settings = "115200,N,8,1" 'Set Comm Settings
'Check if connected by writing down a query and seeing if there is a response
MSComm.Output = "o1.1" & vbCr
Delay (100)
temp = MSComm.Input
If Mid(temp, 1, 6) = "Parker" Then 'If response correct then show connected
Com_led.FillColor = QBColor(10) 'LED to green
Connect = True
Timer1.Enabled = True
Else 'If nothing returned then show disconnected
Disconnect
Com_led.FillColor = QBColor(12) 'LED to red
Call MsgBox("Connection Failed. Check cable and power", vbOKOnly, "Connection Status")
End If
Else
Disconnect 'Is connect if connected
End If
End Sub
Public Sub set_speed() 'speed needs to be in deg per sec motor speed (=output shaft speed * 29/3 * 48/22 for CTPT2, =output shaft speed * 29/3 * 36/22 for CTPVT )
flag_change = 1
next_buffer = "o1902.1=" & Str(speed_value)
Call send
flag_change = 0
End Sub
Public Function motor_stop() ' Stops Motor
flag_change = 1
next_buffer = "o1100.3=0"
Call send
flag_change = 0
End Function
Public Function motor_start() 'Start motor, or effect changed run parameters. Uses motion table row 1 (o1902.1)
flag_change = 1 'Sets flag for send routine
next_buffer = "o1100.3=0" 'Send ACK to clear buffer
Call send
next_buffer = "o1100.3=16643" 'sets start bit low as start needs to see a rising edge
Call send
next_buffer = "o1100.3=24835" 'Sets start bit high.
Call send
flag_change = 0
End Function
Public Sub send() 'Send data to servo under control
delay_time3 = Timer
memo_int = Servo.Timer1.Interval 'Disabling timer seems to set interval to zero
Servo.Timer1.Enabled = False 'Stop auto timer
drive_indata = ""
Servo.txtBack.Text = "" 'Clear TextBox
servo_sending = 1 'Set busy flag
If Connect Then
'if connected then send the buffered strings to the C3, then clear the buffer and Comm input
If flag_change = 1 Then buffer = next_buffer 'Does not set buffer parameter until auto timer stopped
If buffer <> "" Then
buffer = buffer & vbCr 'Add a carriage return
MSComm.Output = buffer 'Send the buffered commands
Servo.Delay (5)
buffer = "" 'Clear the buffer
drive_indata = MSComm.Input 'Clear the receive buffer
Servo.txtBack.Text = drive_indata 'Print received data in textbox
End If
'Query and update the status word value from C3 T11
MSComm.Output = "o1000.3" & vbCr
Servo.Delay (5)
Update_Status (MSComm.Input)
servo_sending = 0 'Reset busy flag
End If
Servo.Timer1.Enabled = True 'Restart auto timer
Servo.Timer1.Interval = memo_int 'Reset timer interval to original setting
End Sub
Hope these help, and good luck! By the way, I found that the "current speed" returned by the Compax 3 was unusable as a process control variable - it seemed to be the instantaneous speed of the drive, which was varying. I use a separate rotoary encoder to get a true measure of speed these days.
10-01-2013 07:28 PM
Hi TWGomez,
I'm currently trying to figure out how to get my compax3 working...to tell you the truth i'm a little new in all of this (labview). In the past, I was able to send simple commands to a controller (Velmex controller) to turn a step motor through labview. And those were pretty easy. With the compax3 however, I'm not sure what the manual(s) are talking about.
All I would like to do is to send commands to the compax3 so that it could let a ETH Parker linear cylinder extend/retract at for any desired length...that is all... really. I just do not know where to start. Please any labview code(s) you or someone on this post has and willing to share will be greatly appreciated.
10-01-2013 07:40 PM
You have to configure the Compax3 and get it working with C3ServoManager before you can do anything in LabVIEW. Did you buy this from a local distributor? They should be able to help you with that at least. Tackle the LabVIEW after that.
10-02-2013 07:49 PM
Ok. Will do and let you guys know after....appreciate it. Thanks.
01-03-2014 10:49 AM
I've written a C# program to communicate with my compax I11T30. Once I created a program and loaded it onto the drive I was able to communicate with the C# program. One workaround is that I had to use INT to BOOL conversion with the codesys software instead of a control word, although now I think I know how I could have set up the control word to fit my custom application. Anyhow, there are plenty of integer inputs in the array tables so I probably won't go back and fix it. Here is a little bit of the code for motor control via serial port communication. Fastest it seems to accept commands and provide a response is 10mS (100 times/second).
