05-12-2016 08:01 AM
What will the tutorial be, any slides available?
05-12-2016 11:39 AM
I just published some slides in the Documents section. I'll put the sample code up there as soon as I can get access to it (technical difficulties). See you later!
05-12-2016 01:35 PM
Sample code uploaded!
05-15-2016 08:52 AM
mgi has a good write up on AF:
http://www.mooregoodideas.com/actor-framework-basics-part-1-the-background/
Also here is a link to the Actor Monitor Add-on (by MGI as well), that was mentioned at the end of the group meeting. It shows you all the actors and gives you a way of stoping them if your stop isn't working right.
06-04-2016 02:51 PM
I have created the CLD practice ATM exam in Actor Framework
If ppl think it's of value to spend 20-30 min looking at this at the next meeting, I could bring my laptop.
p.s. of course, this being my frist project in AF - don't expect perfection, but I would gladely use some pointers.
I have also used the monitor actor add-on to monitor my actors properly shutting down.
06-13-2016 03:42 PM
That would be great! Bring it and we can certainly fit it on the first part of the meeting and perhaps give some pointers.
