Machine Vision
connect reference for twain labview
how to set Twain reference
i have a scanner and need to control it via labview using twain driver ..the issue in how to set the reference in the code
any help plz
(3,754 Views)
could you send code in lv 2014 ?
(3,740 Views)
(3,737 Views)
if you install driver well and also if you have related active x ( i do not have it )
in active x box you can select a scanner for creating reference
here is some site that may help you
http://www.alliancevision.eu/products/softwares-drivers/drivers/vi-labview-library-for-twain-protoco...
http://www.ciansoft.com/samples/default.asp
(3,710 Views)
thnx alot
(3,687 Views)
your wellcome
(3,682 Views)
