I want to use the SQL Toolkit (v.2.06) to connect a MS sqlserver(v.200 pro) database.
So the problem deals with DBcreateTablefromMap() when you use previously the function DBMapColumn ToChar!
There is no problem with DBMapColumnToInt function and with a connection withMySQL .
So, The ERROR Message returned by CVI is: " Function DBcreateTablefromMap : return value -10 "
The problem is due to A DBCreateTablefrommap and just with SQL Server...so, Idon't understand why?
thanks a lot for your help!
