LabWindows/CVI
problem with SetTableCellRangeAttribute
I have a table control in CVI that can have up to 3000 rows.
Row 1 will always be text, and row 2 will always be float.
When I use SetTableCellRangeAttribute to set row 1 to accept a string, I get a protection fault.
But it only happens when I have more then 2390 rows.
When I have 2390 rows or less it works perfectly.
this is my code
SetTableCellRangeAttribute (pnlMain, PANEL_MEAS_TABLE,
MakeRect (1, 1, theMicroplate->NumberSamples, 1), ATTR_CELL_TYPE,
VAL_CELL_STRING);
Now the problem is definately not in theMicroplate->NumberSamples, because I have debugged it and also just replaced it with numbers to verify there were no problems.
The fault is tied to the number of rows specified.
Any
ideas?
(2,644 Views)
I tried creating 3000 rows, first defined as numerics, and I then converted one row to type string as follows:
for(i=0;i<3000;i++)
InsertTableRows (panelHandle, PANEL_TABLE, -1, 1, VAL_CELL_NUMERIC);
SetTableCellRangeAttribute (panelHandle, PANEL_TABLE, VAL_TABLE_ROW_RANGE(5), ATTR_CELL_TYPE, VAL_CELL_STRING);
Make sure you use the VAL_TABLE_ROW_RANGE macro when selecting a range in the SetTableCellRangeAttribute () function.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(2,644 Views)
