LabWindows/CVI
Operands of != have incompatible type
  I have the following problem when compiling my fonction:
"int f_ReceiveCom(int portCom, char EndTerm, int CountTerm, char *buffer,double timOUT)
int Index=0,
Compt=0;
char Oxbuffer[1024];
memset(buffer,'\0',1024);
memset(Oxbuffer,'\0',1024);
SetComTime (portCom, timOUT);
if(EndTerm != NULL)
do
i got the following error "Operands of != have incompatible type",  i tried with strcmp but it does not work
can anybody have idea about why this issue happen, <hy i cannot compare these two terms.
SASA
(4,239 Views)
NULL is defined as a (void *) and is not comparable with a char.
If you want to test for char not zero you can simply use if (EndTerm) { }
On the other end, a char is not a string (which should be a char *) and cannot be used inside strcmp instruction. A char can be treated as an integer value (it actually is an 8-byte integer)
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(4,230 Views)
