LabWindows/CVI
MakePathName error, though header file included
I use the makepathname() function found in utility.h, which I did include at the top at my code, and have shown in my list of .h files.
Also, Options>>Build Options...>>Require function prototypes is also checked.
However, I keep getting this error: error: implicit declaration of function 'MakePathName' is invalild in C99. Make sure that you include the function prototype. I need help with this.
(4,491 Views)
Accepted by topic author hn_sofec
Check for upper case typos. The function ist called MakePathname ( not makepathname or MakePathName) .
(4,479 Views)
Another suggestion is to look at the sample userint\custctrl\hyperlinkctrl\simple.cws - it builds fine and should also work on your computer. If so, you can check the differences...
(4,476 Views)
Thank you so much.  It is a typo.
(4,453 Views)
