save data from graph
hello
i have x-y plot, & i want to save data from graph
what should we done???
Message 1 of 11
(4,646 Views)
Could you be more specific: what exactly do you want to save, where do you want to save it... ?
Message 2 of 11
(4,642 Views)
Right click on the graph, "export" to various file formats.
Message 3 of 11
(4,635 Views)
@mz-nap wrote:
hello
Yse you need to be clear with the question. If you want to save the data that is currently displayed in the graph you can use the Export method else you have to write whatever data that is comming to the graph ( Create a wire branch from the input of the graph to a file i/o.
Message 4 of 11
(4,619 Views)
i want to save data from one graph that is in my attach file and save it to excell file or other related file, i can't get good relation between my graph and save function
plz help me
tnx
Message 5 of 11
(4,613 Views)
i don't see anywhere you are trying to save the data to a file a normal write to spreadsheet.vi is suffucient. Check the attached code. Also try to avoid the sequence structure and follow a standard design pattern (Eg: State machine).
Message 6 of 11
(4,610 Views)
hi
thanks alot for ur answerSmiley Very Happy
but i want to put push bottom that when i pushed it start to save data from graph
best regard
Message 7 of 11
(4,586 Views)
Then you have to change the design pattern so that your concept will best fit. Try going to State Machine or Event Driven State machine.
Message 8 of 11
(4,581 Views)
Hi
I am new in labview and i want to read this raw data in labview and convert it to decimal by reading each line and the results is saved in excel file
can i be able to have an idea how to go about this kind of project?
Thanking you inadvance
Message 9 of 11
(4,263 Views)
This seems unrelated to the original thread. Please start a new one with details such as where the dats is coming from, what do you mean by convert to decimal, and what you have done so far. Attach your code.
Message 10 of 11
(4,249 Views)
