rs232 pic16f887
Bonjour
Je réalise une interface de supervision avec le logiciel Labview.
Dans une des étapes, je fais ceci :
De mon microcontrôleur j’envoi deux variable pour chaque LED.
-          Une variable pour éteindre la LED
-          Une variable pour allumer la LED
Problème
Quand j’envoi une variable pour allumer la LED_1, par exemple, ça fonctionne. Mais quand j’envoi une autre variable pour allumer la LED_2, la LED_1 s’éteint.
Merci pour votre aide.
(3,365 Views)
english do please!!!!!!
"Thanks with regards "
by
..........Gireesh..........
(3,363 Views)
Hello
I realize a monitoring interface with the Labview software.
In some stage, I do this:
Microcontroller's I send two variables for each LED.
- A variable to turn off the LED
- A variable to turn on the LED
Problem
When I send a variable to turn on LED_1, for example, it works. But when I send another variable to turn on LED_2 the LED_1 off.
Thank you for your help.
(3,358 Views)
(3,336 Views)
         Without Labview you can do this. If you are trying to do this with labview
Hello
   for my knowledge, please tell me why this is moved to this problem to that link. thank you for your kind information
Hello younesser
I could not understand what is your actual issue, Whatever it is? You do one thing, all LEDs put on both cases and whatever LEDs should ON in case give TRUE and others give FALSE. In the other case give reverse of this conditions. It will work, sure. This answer is given from the diagram whichever you are given. Whatever, try your logic, and you can able to get.
by
(3,314 Views)
Hello
Hello younesser
The link I posted was incorrect. It was intented to point to the other thread the user started (http://forums.ni.com/t5/LabVIEW/rs232-pic16f887/m-p/1580682). The discussion should be kept in one place.
(3,307 Views)
