cluster
Hi! When I've defined an output cluster with 8 elements,
how can I write only 3 values in this cluster, because the other 5 I don't need right now??
(2,590 Views)
Hi
I usually create a constant of this cluster, wire it to a bundle by name node, wire the necessary values and wire the output to the cluster terminal.
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,584 Views)
Use the Bundle by Name function in the Cluster subpalette. Wire the cluster value or a corresponding constant to the function input (you can create the constant right-clicking on the cluster terminal and selecting Create->Constant), then select the names of the elements you need.
Finally wire the output to the indicator.
Paolo
(2,583 Views)
It would be better to wire the cluster value than a constant cause the unwired entries will take the value of the constant. If your use a local var of your cluster, the unwired entries will keep the same value.
Yann
Yann Falevoz
R&D Engineer, Instrumentation & Software
(2,565 Views)
If there's a while loop it would be better to use a shiftregister if there is data written at several places. This reduces the memory usage as no locals are necessary.
Using LV8.0
(2,562 Views)
