06-06-2006 09:11 AM
06-07-2006 10:59 AM
Hi Jim,
I am thinking that you are looking to control the size of the individual plot areas (i.e. the individual graph areas). The way you would normally do this in LabVIEW is by using the Active Plot Area property to select which plot is currently active. Then you would use the Plot Area Size property to change the size of the active plot. Unfortunately, this behavior does not work as expected in LabVIEW 8.
Engineering is aware of this issue (# 3T2BA63A) and it is currently under investigation. We don't currently have a timeline on when updates will be made to this issue, but I know R&D is looking to address this in a future version. I apologize for the inconvenience.
Best Regards,
Megan B.
06-12-2006 07:58 AM
Thanks for the information Megan B. If the behavior gets corrected in the future, how would I know?
Cheers,
JMA
06-13-2006 10:38 AM
Hi JMA,
This issue is in the report 3T2BA63A so all you need to do is ask for the status of this report when a LabVIEW upgrade is released. If you have a service contract, you can call in and ask an Applications Engineer, or you can simply post here on the discussion forums.
Let me know if you have any questions!
Megan B.
06-27-2006 04:19 PM
07-26-2006 02:37 PM
Wonger:
I have experienced other problems with the Mixed Signal Graph - namely that the plots blend together when dragging and then can't be separated - has this been fixed also in 8.1? I was also experiencing Labview (8.0.1) crashes when using this control - these crashes have gone away since I reverted to the Chart control. I have a real need for the Mixed Signal Graph and would really like to use it but can't with the problems I was having - any time frame on release of 8.1?
Thanks ......... Ray K.
07-26-2006 02:47 PM
07-27-2006 06:51 AM
