XY graph display uncertain number lines.
Dear all,
I want to display uncertain number lines on a XY graph, and the number of lines is typed by the user. How to do this?
Mei
Message 1 of 21
(3,423 Views)
The graph will display as many plots as you put into the array you wire to it, that number doesn't have to be fixed. You can change properties of the graph to adjust the number of plots shown on the legend, and the style and color of each plot drawn on the graph, on the fly.
Message 2 of 21
(3,415 Views)
What is a "uncertain number line"?
Do you just want to display multiple plots? Are the x-values evenly spaced?
Is the number of plots fixed and you want to select/view a subset? Look at the visibility checkbox.
It would probably help if you could attach a simple VI.
Message 3 of 21
(3,412 Views)
While I am not sure abou the currnet version of LV but at one time, we would get errors if we presented more plots to a graph at run than there had been plots in the plot legend.... Something about invalid some such.
Ben
Message 4 of 21
(3,378 Views)
The oldest version I have installed is 2015, but in it and 2017 you can create a brand new XY Graph with only one plot shown in the legend and feed it an array of 100 plots, and it'll graph them all using assorted default colors.
Message 5 of 21
(3,376 Views)
You got an error if trying to set an "active plot" property for a plot that does not exist yet. (e.g. if you have 100 plots and try to set the color of plot # 102 via a property node).
You can wire more plots than legends and that worked always.
Message 6 of 21
(3,370 Views)
Thanks, I can change the display number by your method, but I still  do not know how to write the input. I got an array(the dimension is typed by users ) as output from an instrument, now I want to display these lines (the first dimension is the x value, and y values respond the remaining dimension). How to write these? Can I explain clearly?
Message 7 of 21
(3,350 Views)
Thanks. "uncertain number line" means I do not know the number of lines displayed as the number is typed by the user. The x value is from the instrument and the number of plots is not fixed. I got an array(the dimension is typed by users ) as output from an instrument, now I want to display these lines (the first dimension is the x value, and y values respond the remaining dimension). I am very sorry I still do not know how to begin this vi, so I cannot upload a sample...
Message 8 of 21
(3,349 Views)
So all y traces share the same x-values? You still have not said if the x-values are evenly spaced.
Message 9 of 21
(3,345 Views)
Yes, all the y traces share the same x values, and the x value are not evenly spaced.
Message 10 of 21
(3,333 Views)
