‎04-20-2016 04:34 PM
Solved! Go to Solution.
‎04-20-2016 04:51 PM
the XScale property is a number from 0 to n - 1, where n is the number of X Scales you have on your graph (usually 1).
Here is an example of a graph with 3 X Scales and 2 cursor associated with scale "Time" and "Time 2" respectively.
The reason why this matters is that the X Values you read in the cursor "X" column will be different depending on whether the cursor is associated to one or another scale, as you can see above.
HTH.
‎04-20-2016 04:56 PM
‎04-20-2016 05:00 PM
‎04-20-2016 05:09 PM
If you only have one X scale, then the only value it will accept is zero, since that's the index of that cursor.
I remember you having the cursor not moving issue a few days ago, I think. Did you ever manage to post a VI that has the problem displayed the instant it's loaded so we can see the issue? Without that it's very hard to debug your issue, as graphs have a ridiculous amount of property nodes to get or set.
‎04-20-2016 05:33 PM
‎04-20-2016 05:49 PM
