TDS5034
  The TDS 5034B is a different scope that the TDS 3054B, therefore the possibility does exist that the scopes have a different command set that will result in the vi that was intended for the 5034 scope to fail. I would suggest that you obtain the programmers manual for the 3054B and go thru the vi to verify that the commands are the same (or different) for the scope. If I had access to the 3054 scope in may lab I would check it out for you.
   If you are still having problems, I could repost the latest code for the 5034B scope so that you have a up to date starting point for getting the 3054 scope to work. Please also let me know what interface you are using on the scope. The 5034 has 2 interfaces, GPIB and ethernet, which one are you using?
Kaspar
Message 41 of 48
(2,168 Views)
I have a VI for getting a hardcopy from a Tektronix 3034B but the bmp file is a bit distorted. Can anyone help with what I am doing wrong?
Message 42 of 48
(2,122 Views)
  I looked at your code you are writing the data as a text file, the screen data is binary. Try using the vi called "Visa Read to File" , this will take the data and write it to a file in one step.
Kaspar
Message 43 of 48
(2,117 Views)
Thanks Kaspar that worked.
Message 44 of 48
(2,105 Views)
  Great...I am glad it worked for you!
Kaspar
Message 45 of 48
(2,095 Views)
Hello,I have an oscilloscope TDS3014B
I want use the command "hardcopy" to do the  screenshot.when I use the port GPIB,my VI does work, but when I use the portethernet,it doesnot work.
When i choose the ethernet,the VISA can find the TDS3014B,and the *IDN? can read the scope information.
my comand is as list
hardcopy:format bmp;
hardcopy:port gpib;
hardcopy start
the vi does work
but
when i choose
hardcopy:port ethernet;
hardcopy start
it doesnot work,why?
Message 46 of 48
(1,739 Views)
Hi
can I get the programmers  manual for TDS5043B? and can you please suggest the way how could I recall the .set file from DSO when I run my application.I am using the tektronix 7000 series instrument drivers and acquiring the data. communication between Labview and DSO is using ethernet.
Message 47 of 48
(1,133 Views)
Hi sp,
Why don't you ask Tektronix?
Message 48 of 48
(1,130 Views)
