TDS5034
  I just wanted to post the vi that I wrote in case that someone else wanted to use it to get a screen snapshot of the scope. Or maybe it could be included in the next release of the scope drivers.
 Kaspar
Kaspar
Message 11 of 48
(3,764 Views)
Kaspar,
Thanks for posting your code!  I'm sure it will help another person if they run into the same snag that you did!
Jared Boothe
Staff Hardware Engineer
Message 12 of 48
(3,750 Views)
Kasper,
Do you have this VI in an earlier version of Labview? I am using 8.0 here? If not is there any other way you could get me the code?  Thanks
Kirk
Message 13 of 48
(3,739 Views)
  I have tried 6 times to reply to your request with a BMP file of the block diagram as a attachment and every attempt has failed. I will try later on, hopefully it will work then
Kaspar
Message 14 of 48
(3,705 Views)
You are not allowed to post bmp files. You can post png or jpg files but it would be much better if you just saved the VIs to an older version. Open the VI and then select File>Save for Previous Version.
Message 15 of 48
(3,700 Views)
  How about a gif file fo the block diagram?
Kaspar
Message 16 of 48
(3,698 Views)
Ok thanks I will give this a shot!
Kirk
Message 17 of 48
(3,693 Views)
  Ok, it appears that the file size and/or the bmp extension was the reason why I could not attach a BMP file. The gif works, but the readability is not there. How about the attached PDF file for the code?
 Kaspar
Kaspar
Message 18 of 48
(3,687 Views)
Yes looks great! Thanks so much! I was having trouble printing the gif file!
Message 19 of 48
(3,680 Views)
Kaspar,
Since you seem unwilling to do a simple save as, I did it for you.
Message 20 of 48
(3,678 Views)
