Rotate an object around multiple axes
Hi guys, I'm a little bit confused about the machanism of how to rotate an object in 3D picutre.
My goal is to let a cone pointing at the origin at any given position, but it seems it's hard to rotate the cone with the 'set rotation. vi' around more than 1 axis.
Is there any intuitive way to rotate an object?
It is at (2,2,2), initially it points up in z axis
This is what I want, (I set (1, -0.2, -0.3) and 135° in set rotation. vi, it works but I don't know why Smiley Frustrated)
Thanks a lot !!!
yhs
(3,523 Views)
the axes of rotation will be the cross product of (the vector from origin to cone) and (orientation of the cone).  The angle of rotation can be calculated from these two vectors as well.
The vectors would be [2,2,2] and [0,0,1] as you have the VI set up currently.
(3,487 Views)
Thank you very much, it works
(3,450 Views)
