10-31-2014 02:15 PM
I have several discrete tasks defined using NI Max. How do I bundle them together in LabVIEW as a single task? I don't want to use NI Max to create the compound task. I want to do it programatically so I can pick the discrete tasks I want.
10-31-2014 02:38 PM
Should work fine
11-03-2014 07:21 AM
Thanks, but where do I find (and what is) the Vi between the for loop and the create task VI? I cannot find it on the palette. I'm running 2014.
11-03-2014 08:45 AM
DAQmx Flatten Channel String (VI) <script type="text/javascript">// var L_helpType = "STD_ENG"; // </script> <script type="text/javascript">// var L_taskconfigchm = "taskconfig.chm"; // </script> <script type="text/javascript">// var nofeedbacklink = true; // </script> <script src="/t5/forums/replypage/board-id/170/message-id/common.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/jquery-1.7.2.min.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/cssframes.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/domtools.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/arraytools.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/initpagedyn.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/stylesheets.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/web.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/pdf.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/infocodes.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/launchhelpLV.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/launchdaqhelp.js" type="text/javascript"></script> <script src="MS-ITS:glang.chm::/helpserver.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/Variables.js"></script> <script src="/t5/forums/replypage/board-id/170/message-id/cssframes.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/launchhelplv.js" type="text/javascript"></script>
Converts an array of physical or virtual channel names to a comma-delimited list of names. You can use this VI to convert an array of channel names to a single string prior to using the DAQmx Create Virtual Channel VI or the DAQmx Create Task VI.
11-03-2014 09:08 AM
11-03-2014 09:16 AM
Thanks. I though it was just an image. It didn't occur to me to try to copy it.
