Remove NaN
How do i remove the NaN in "output/input" array. Also i need to display the top column of "200077670" array like "2000776729".
Message 1 of 40
(19,914 Views)
When you divide a 0 by 0 it will give you NaN. Check the values coming in the denominator is a non-zero value since you are trying to calculate percentage (I Guess).
Good Luck.
Message 2 of 40
(19,901 Views)
Some of my denominator has values. Is it possible to display it in "0" instead of NaN for both non values and with values?
Message 3 of 40
(19,877 Views)
yes you have to check the values as NaN if true pass 0 else pass the value. You can perform this inside the for loop.
Message 4 of 40
(19,872 Views)
something like this?? not very good in this...new to LV
Message 5 of 40
(19,857 Views)
I use this to remove NaN from my arrays, hope this helps.
Epictetus
Antoine Chalons
Message 6 of 40
(19,850 Views)
Thanks Smiley Happythat was good but i am required to show the "0" array instead of removing itSmiley Frustrated
Message 7 of 40
(19,847 Views)
well then just replace the "delete from array" primitive with a "replace array subset primitive" or better with an inplace structure.
Epictetus
Antoine Chalons
Message 8 of 40
(19,842 Views)
Accepted by topic author nyp123
I generally use the following method. 1st one replace the NaN with 0 and the 2nd removes the NaN.
Good Luck.
Message 9 of 40
(19,833 Views)
you'd be slower on large arrays 😛
Epictetus
Antoine Chalons
Message 10 of 40
(19,830 Views)
