How to disable selectability of front panel indicators
I have a VI whose front panel is shown below where a String Indicator is having an issue. The indicator here reads the value 'Please record the value for Air Temp [C]'.
Problem
When the indicator is clicked on in the front panel the text area becomes 'editable' in appearance (only) and I did not want this
Question
How do I eliminate the behavior shown below in Picture Two, when the indicator displays as editable? How can I leave the system simply in a state of Picture One :)?
Picture One - Normal Front Panel
Picture Two - Front Panel with Click on String Indicator
justinmreina@gmail.com
Message 1 of 9
(4,270 Views)
Can you attach the VI instead?
Clickability is useful of you e.g. want to copy whatever is shown in the indicator. (I hate it if I e.g. get an error message and it won't let me copy/paste it into an error report!).
You can always use a "mouse down?" filtering event for the string and discard it.
(Why is the string area in the lower picture so larger? Seems you have overlapping controls. One line would be sufficient.)
Message 2 of 9
(4,261 Views)
Accepted by Justin_Reina
Justin,
Try disabling the indicator. Property node or right-click Advanced -> Enabled State -> Disabled.
steve
Help the forum when you get help. Click the "Solution?" icon on the reply that answers your
question. Give "Kudos" to replies that help.
Message 3 of 9
(4,253 Views)
Problem
Question
Hi to be more clear refer to the image below
you can right click on the string indicator go to advanced -----> Enabled State and select disabled.
Certified LabVIEW Developer
Best LabVIEW Programmer @NIDAYS 2015
Message 4 of 9
(4,227 Views)
Attached vi will do what you want.......
There are  two ways to tell s thanks in forums : either give Kudos or  Marked Solutions
Message 5 of 9
(4,217 Views)
What I like to do is make the Caption of the entry visible and then I edit the caption with a property node.  It looks just like the string indicator you have and the user cannot select it.
GCentral
Message 6 of 9
(4,209 Views)
Personally I would use Tim's solution to use the caption because in addition to giving you the behavior you want, it is also logically correct.
Look at the front panel you designed. The line about entering data is clearly associated with the input box. Logically it is already functioning as a caption ("Value" means nothing and would be confusing to the user) so make it the caption.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 7 of 9
(4,198 Views)
On mobile. So I can not add browsers tabs or, add a link.Smiley Embarassed
Up
See also a Community nugget of mine.  avoiding the three finger salute!
Hint: tag "my nuggets" with an underscore.
"Should be" isn't "Is" -Jay
Message 8 of 9
(4,152 Views)
Oh my goodness, how naive of me. This works!!!!
Thank you, and my apologies for the silly error!
Message 9 of 9
(4,106 Views)
