06-03-2016 05:14 PM
I have a VI whose front panel is shown below where a String Indicator is having an issue. The indicator here reads the value 'Please record the value for Air Temp [C]'.
Problem
When the indicator is clicked on in the front panel the text area becomes 'editable' in appearance (only) and I did not want this
Question
How do I eliminate the behavior shown below in Picture Two, when the indicator displays as editable? How can I leave the system simply in a state of Picture One :)?
Picture One - Normal Front Panel
Picture Two - Front Panel with Click on String Indicator
06-03-2016 05:25 PM - edited 06-03-2016 05:28 PM
Can you attach the VI instead?
Clickability is useful of you e.g. want to copy whatever is shown in the indicator. (I hate it if I e.g. get an error message and it won't let me copy/paste it into an error report!).
You can always use a "mouse down?" filtering event for the string and discard it.
(Why is the string area in the lower picture so larger? Seems you have overlapping controls. One line would be sufficient.)
06-03-2016 06:01 PM
Justin,
Try disabling the indicator. Property node or right-click Advanced -> Enabled State -> Disabled.
steve
06-04-2016 01:34 AM
@Justin_Reina wrote:I have a VI whose front panel is shown below where a String Indicator is having an issue. The indicator here reads the value 'Please record the value for Air Temp [C]'.
Problem
Question
Hi to be more clear refer to the image below
you can right click on the string indicator go to advanced -----> Enabled State and select disabled.
06-04-2016 04:35 AM
Attached vi will do what you want.......
There are two ways to tell s thanks in forums : either give Kudos or Marked Solutions
06-04-2016 06:59 AM
What I like to do is make the Caption of the entry visible and then I edit the caption with a property node. It looks just like the string indicator you have and the user cannot select it.
06-04-2016 10:19 AM
06-05-2016 12:07 PM - edited 06-05-2016 12:11 PM
On mobile. So I can not add browsers tabs or, add a link.
Up
See also a Community nugget of mine. avoiding the three finger salute!
Hint: tag "my nuggets" with an underscore.
06-06-2016 11:31 AM
Oh my goodness, how naive of me. This works!!!!
Thank you, and my apologies for the silly error!
