How to delete NI MAX shortcut
Hello all,
I have small issue. Please help me.
As per below image, I have added NI MAX in my application (when I created application).
When I installed my installer in other PC, NI MAX shortcut is created in programs menu & desktop.
But I don’t want this shortcut in programs menu. Is there is any options to disable this shortcut when we are building application (Installer)?
Munna
Message 1 of 8
(3,132 Views)
Hi Munna,
usually you can start your own executables/batch scripts in the setup process before and after your LabVIEW executable is installed.
Why not write a small batch file to delete those entries after installation?
Message 2 of 8
(3,113 Views)
Hello
Open   Start Menu
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
Message 3 of 8
(3,111 Views)
Dear GerdW,
Thanks for your nice idea 🙂 .
I want to confirm one thing, usually I don’t have admin rights to change/modify any of the files from Program menu.
I have only admin rights to install my specific application. Is this batch file will works without admin rights?
Munna
Message 4 of 8
(3,100 Views)
Hi Munna,
I don't know. But I hope the whole installer ("setup.exe") and all executables called by setup.exe are run with the same admin rights…
(Maybe someone from NI might clarify that issue.)
Message 5 of 8
(3,094 Views)
Dear GerdW,
Thanks for your reply.
Usually how many exes we can add at this place. Because I have already added one exe.
Is it possible to add another exe here ?
Munna
Message 6 of 8
(3,088 Views)
Hello Syrpimp,
Sorry to say, I haven’t got any information about my issue from this link.
Munna
Message 7 of 8
(3,082 Views)
Hi Munna,
you can call a batch file. And in the batch file you can call as many executables you want…
Message 8 of 8
(3,079 Views)
