01-30-2015 06:20 AM
Hello!
I found this project but when i try to run it, there is an error (error-200684). Why?
I'm not able to use labview program but i need a similar project.
I enclose to you the project and the immage of the error
01-30-2015 06:52 AM
What is the voltage that you reading? I'm guessing it is a negative number. That would cause your error.
01-30-2015 06:56 AM
In the immage attached the voltage is not negative, the voltage value is 2,46254 Volts.
01-30-2015 07:06 AM
Ok, just played with the VI for a little bit.
If the measured temperature is greater than the setpoint, then you will get a negative output from your PID. You might need an offset in there or just limit the output to not go below 0. I would just use the In Range And Coerce function to limit the range that your output could be.
01-30-2015 07:12 AM
Can you tell me step by step how, please?
I have never used labview.
Thank you.
01-30-2015 07:29 AM
Here's a snippet of the VI I made for troubleshooting purposes. I added in the In Range And Coerce function to the output of the PID function.
Since you are brand new to LabVIEW, I highly recommend taking some of the free online tutorials that are out there.
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
Learning NI
Getting Started with NI Products
01-30-2015 08:06 AM
I tried to modify the project on your advices. I compared your scheme with mine.
However the program don't run.
01-30-2015 08:09 AM
You still need your divide by 100 in there.
01-30-2015 08:17 AM
where?
02-02-2015 03:06 AM
Hi Vitamina,
since you are new in LabVIEW programming, let's try to follow the instructions in this tutorial.
I think it will help you.
Kind regards.
Cla_CUP
NI ITALY
