07-07-2014 11:54 AM
Ok, here are the screen shots of the main VI and subvi
07-07-2014 12:16 PM - edited 07-07-2014 12:26 PM
Ahh, my eyes, my eyes!!! Besides the easter egg diagram color scheme, there is really very little we can tell from a picture, especially is you have sequence structures stacked 10+ frames deep. What's up with all the coercion dots?
So it seems that the subVI is called one point at a time. All you need to do is assign a terminal to the chart and read it in the main IV.
07-07-2014 12:25 PM - edited 07-07-2014 12:28 PM
I don't know what coercion dots are @.@ Sorry about the colors XD i got bored at one point >.> ... <.< ... if you notice, the icon for the main VI is a kitty +.+ ...
I tried assigning a terminal in the subvi to the chart. Do I insert the exast same chart in the main vs and connect the terminal from the subvi to it? When I did that the main vi first complained that it needs to be attached in every frame, then when I got to the last frame it suddently started complaining that it doesn't know which way the information is going 😞
07-07-2014 12:27 PM
Stop using stacked sequences! 😄
07-07-2014 12:29 PM
But ... it's the only way I know +.+ ...
07-07-2014 12:36 PM
Then you have to take Tutorials on LabVIEW basics. 🙂
07-07-2014 12:40 PM
Well, you clearly have some serious dataflow problems, mostly caused by overuse of stacked sequences and poor understanding of dataflow in general.
A stacked sequence really does very little ... Where did you learn LabVIEW? Maybe you should start with a few tutorials if this is giving you problems.
Feel free to attach your actual code so we can give less general comments..
07-07-2014 12:43 PM - edited 07-07-2014 12:54 PM
I never learned LabView 😞
A few weeks ago, my adviser said "Here, make this work...", so that's what I'm trying to do >.<
So you don't know of a quick simple way to get the chart to show up without rewriting the entire program?
Here are the actual programs just in case. (I inherited the subvis from the last student, so it's not my fault if they're horrendous. >.> I just edited them a bit +.+)
07-07-2014 01:06 PM
Your subVIs dont seem to have any charts.
Your main Vi does not have any charts either, just an xy graph.
Your entire code architecture seems inside-out. How are you running this? The main VI does not even have a while loop!
07-07-2014 01:25 PM - edited 07-07-2014 01:27 PM
isn't that blue thing a chart/plot/graph? %\ ... gah ... that's where the points appeared ... so i just assumed +.+ ... oh gawd, I'm so confused right now ...
The main VI takes as input the number of increments and feeds it into the subvis which have while loops >.>
