LabVIEW Real-Time Idea Exchange
About LabVIEW Real-Time Idea Exchange
Have a LabVIEW Real-Time Idea?
  1. Does your idea apply to LabVIEW in general? Get the best feedback by posting it on the original LabVIEW Idea Exchange.
  2. Browse by label or search in the LabVIEW Real-Time Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  3. If your idea has not been submitted click New Idea to submit a product idea to the LabVIEW Real-Time Idea Exchange. Be sure to submit a separate post for each idea.
  4. Watch as the community gives your idea kudos and adds their input.
  5. As NI R&D considers the idea, they will change the idea status.
  6. Give kudos to other ideas that you would like to see in a future version of LabVIEW Real-Time!
Top Kudoed Authors
User Kudos Count
1
Support industry standard time server (NTP e.g.)
The real-time controllers have a "Time server" IP input in their setup. That is great, but it is not great that the time server has to be a piece of NI software (Logos). If it was possible to specify an NTP server for example (and/or other standard protocols), this feature would be much more useful.
Most of the time we need the PACs to be synced with a third party system.
4 Comments
Active Participant smithd
Are these sufficient for your needs? Or is these some finer level of accuracy/control you are looking for?
http://digital.ni.com/public.nsf/allkb/F2B057C72B537EA2862572D100646D43
https://decibel.ni.com/content/docs/DOC-26987
Active Participant Mads
Sure, the latter one is how we do it now, and is what I would like to avoid having to do.
The request is to make NTP the primary and obvious choice. That means having it in the web GUI, the setup page in NI MAX etc.
I did not know about the support described in your first link, and that is good news...but it should be supported on all targets, and be the obvious choice. Not a hidden feature .
Definitely makes sense to make it more visible, just wanted to point those out Smiley Happy
Active Participant xl600
I've just installed the TimeSync-SNTP and it seems to work pretty well even with LVRT 2014.  Why hasn't this been incorporated into the production TimeSync software?  Having to back up to an older version and suffer the loss of updates is highly irritating and potentially risky.
