User | Kudos |
4 | |
3 | |
2 | |
1 | |
1 |
As far as I understand undo management in XControl, "DisplayState" is memorized each time "State Changed" is set to true in "Action" Cluster. Undo step is limited by the configuration of "Maximum undo steps per VI" in LabVIEW environment.
It would be interesting to have more control on this mechanism:
- be able to clear the undo memory
- be able to skip a memorization when "State Changed" is set to true. (idea : memorized the state only if "Action name" is not empty.
- be able to set the maximum undo step independently from LabVIEW configuration (idea : use the init ability to define this)
Last item wold be useful to avoid too large memory consumption when "Display state" contain lot of data.
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
