falkpl
one click save control as typdef
Status: Completed
Available in LabVIEW 2011 and later
I make many (almost all) clusters and enums typdefs.  This requires a right click go 2 menu levels down to advanced>customize, then select typdef instead of control (which should be the defauld IMHO) then save and the close then select from popup, replace original with control.
I want right click on a control, ->save as typdef, skip the many steps to do what I want.  probably could save a minute or two each day here.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
4 Comments
ssk
Great idea! I would use this feature.
tst
Knight of NI Knight of NI
Knight of NI
In the meantime, you might wish to look at the RCF plugin I posted here. It does not currently replace the constant with the typedef, nor does it work on controls (I'm guessing), but both can be modified.
___________________
Try to take over the world!
crelf
Trusted Enthusiast
Darren
Proven Zealot
Status changed to: Completed
