EricC.
default look of constant
Status: New
by default, when you create a constant, it look 'expanded'
It will by usefull if we cas configure if a constant look expanded or short by default and if a specific type def look expanded or short.
so you don't loose time to resize all your struc when you create a constant of a big cluster !!!
constant look
Ingénieur d'Application / Développeur LabVIEW Certifié (CLD)
Application Engineer / LabVIEW Certified Developer (CLD)
10 Comments
Knight of NI
I understand the basic premise of this idea, but I don't understand what you are trying to show in the second picture. If anything, for the second example the "short look" is larger than the "expanded look". The "short look" there is merely what you get when you select "View as Icon". I'm assuming you're asking why you can't do the same thing as the first example when the constant is a typedef (i.e., double-clicking alternates between expanded and compact look)?
David S.
NI Employee (retired)
Eric, is it not enough to be able to double-click the border of a dropped constant to turn it into an icon? That doesn't seem like a big waste of time to me.
David Staab, CLA
Staff Systems Engineer
dthor
I *think* that Eric C. might be meaning something along the lines of this idea: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Add-Block-Diagram-design-for-typedefs/idi-p/940093
EricC.
Hello all
My example is only a short example;
This idea is more interresting when you use big cluster.
Example 2 :
(imagine whit a complexe vi and with a lot of striuc)
A need to créate une default input
it gives this :
The struc is rezised
so i use the short look version
but a big empty space is in diagram
and i lost time to re shrink the size
of course you cas deactivate the autoresize option, but in this case you lose the constant (the short version is placed to barycenter of the image of the big version)
have a nice day !!!!!
David S.
So you want an option to place all cluster constants on the diagram as icons? That makes sense to me.
David Staab, CLA
dthor
David S. has the right Idea I think. Kudos for that!
EricC.
Exactly DavidS !
simplemaan
My kudo is for idea as expressed by David S. I'd just like an option because creating a constant moves block diagram objects if they are in the way
majoris
Just to be clear, this should be for cluster constants only, but it definitely is very needed. I almost dread putting clusters constants on my block diagrams. They are huge and I have to play clean up every time (by turning them to icons and then resizing every stupid thing). This would be a great feature!
X.
Trusted Enthusiast
Trusted Enthusiast
Don't turn on "auto-expand" in the first place. End of story.
