altenbach
Why is there no function to reverse "Index & Bundle Cluster Array"
Status: New
The function Index & Bundle Cluster Array can be quite useful and mimics a bundle in a for loop.
The reverse operation (= unbundle in a for loop!) would be equally useful.
 I wonder why it is not part of LabVIEW. Seems like an omission. 😉
I suggest to add it with the same icon graphics, but with left and right halves swapped.
(See also this example)
Message Edited by altenbach on 06-17-2009 01:21 PM
9 Comments
altenbach
Knight of NI
The new function could be called "Index & Unbundle Cluster array" 😄
PJM_Labview
Yes ! (especially for the usecase you outline in your screenshot, this will make sorting cluster with pointer a lot nicer [and possibly] faster.)
I almost wrote about that idea a week ago (and then I forgot about it) ...
vipm.io | jki.net
Darren
Proven Zealot
I always wondered if that function existed somewhere, and I just couldn't find it.  🙂  I agree this would be a great addition.
-D
JackDunaway
Trusted Enthusiast
It would be sweet if you could Unbundle By Name here, and it could be resized up and down to only select the items you want. I would not use it otherwise (I avoid Bundle/Unbundle without name like the plague)
altenbach
Knight of NI
The "unbundle by name" version has apparently been suggested here.
TCPlomp
Trusted Enthusiast
This is allready available as an XNode on LAVA, for anyone not wanting to wait.
Ton
My LabVIEW Ideas
ghighuphu
Any news on this topic, please? Cheers, one brave bundle- & array-fighter
X.
Trusted Enthusiast
Trusted Enthusiast
As TCPlomp pointed out, the XNode works just fine. if you use VIPM, it is a snap to install. Just don't forget to install the lava_lib_LabVIEW_API_scripting_tools library first, as it is needed.
ConnerP
I have been using LV for 4 years now and never noticed Index & Bundle Cluster Array. Holy crap thank you for that!
